Old 01-20-2011, 09:54 AM
Rob37 is on a distinguished road
Mach-3 Question
Is there a setting that I am missing in Mach3 that raises the cutting head above the work surface before moving to the first cut area? When I zero out my work surface than hit cycle start the cutting head stays at zero to move to the first cut. This can cause big problems if the surface is uneven or clamps are involved. Is there some setting that I am not aware of in Mach3 to retract from zero for the first cut move?
Rob 37
Old 01-20-2011, 10:13 AM
WayneHill's Avatar
WayneHill is on a distinguished road
Rob37,
The first line of the program can be X0. Y0. Z.1
Wayne Hill
www.codemangler.com
Old 01-20-2011, 10:44 AM
ger21's Avatar
Once you hit cycle start, Mach 3 does what the code tells it to do. AS Wayne said, the typical way of doing things is for the first line of g-code to raise the tool.
Another thing you could do, is goto safeZ after zeroing. But you'll still be at the mercy of the g-code, so you're g-code really should be handling the issue.
Old 01-21-2011, 09:19 AM
Thanks Lots
Hey you two, thanks for such good info and a quick response. I'm still such a newbie at this stuff that sometimes it makes me feel like a real bonehead.
Rob37
Mach 3 question csmoak25 Mach Software (ArtSoft software) 1 03-17-2010 05:09 PM
mach 3 question vz58 Benchtop Machines 3 02-14-2010 08:32 PM
mach III question woodman08 Canadian Club House 2 12-23-2007 08:10 PM
I know it's a Mach 3 question.... Smitty911 Benchtop Machines 4 11-30-2007 07:16 PM
Mach question cncman2 Mach Software (ArtSoft software) 0 03-31-2003 12:42 PM
