| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Hi All, My first steps into the CNC World.. I have build a machine, and am using a 3 axis TB6560 driver board.. ( I know cheap stuff) I was on a budget. ![]() I have the board working and the motor's are turning when I use the Jog buttons in Mach 3. BUT... When the motors are turning I can stop them with my fingers, I don't think that is a good thing. I am thinking this is a setting problem somewhere. The voltage I am using is 24V and the motor's used are these: ftp://ftp.phytron.de/phytron-usa/ste...ors/zss-us.pdf The Phytron ZSS 56-200 Any idea's ? With kind regards.. Last edited by rwijbenga; 01-20-2011 at 01:21 PM. |
| I too am fairly new to homemade cnc. I have a purchased kit that total works, but I purchased this kit from ebay, 3 Axis Nema 23 stepper motor 287 oz.in CNC Router NEW on eBay.ca (item 280612051870 end time 06-Mar-11 00:51:38 EST) the board number is, 3 Axis Driver Board TB6560 3.5A, however I believe in the instructions that came with it, it has TB6560M, not too sure if it is the same board as yours. I too am having trouble, but I can't even get the motors to turn continuous during jog mode in continuos mode. If I select step mode the jog works for the step I set. If I run a file, the motors don't really spin, but the numbers in Mach change as if they spin. Was wondering if this is the same controler you have, and if so would you be willing to send the XML file for Mach. This is the configuartion file that saves all the settings, Thanks, |
| Hey there reichert, wondering if you've had any luck with finding pins/settings for that board yet... I ordered from the same supplier but the 4 axis version Nema34 stepper motor 878oz.in & 4 Axis Driver Board CNC on eBay.ca (item 270681060017 end time 15-Apr-11 02:46:03 EDT) and am running into the same issues, I can get one of the motors to "kinda" spin "sometimes" trying a number of settings on the dip switches aswell as in Mach 3 however am also totally new to all this so its very possible im making some very silly setup errors........... |
| i sort of have things working. I used the pinouts from the instruction, they all worked, i just didn't spin, so I had to lower the velocity and accelertion values, i think my velocity is set to 20 and accelertion is set to 4, i have set to full power, 1/2 step and decay is both dips are on. if i increase velocity, then motors have no power and stall out. If I increase too much, like about 70 or so, then the motors just vibrate and not spin. These motors all really crappy, and I never really got any help from them. I did complain enough and they refunded part of it. I endded up changing the motors out to 2 amp, 65 volt, get a little more speed, but only running 24 volts, so I need a bigger power supply, but these boards only handle 36 volts max and read i everywhere they will burn out. So for now I just run them at max 20 ipm until i buy a new board. It is a little slow, but at least they work. Also in the Mach software I selected the Sherline 1/2 step. This is the same place you set the 35000 hz when setting up, Sorry for the some unclear info, I am at work and I don't have the info here, so doing this from memory. I also tried Linux EMC2 and found that is was even worse speed and very hard to configure. So what I would do first is lower your acceleration to 10-15 and acceleration to 4, the other 2 values beside these that are sert to zero, i changeed to 2 each. Hopefully this will get you spinning, that is what worked for me. then just play with slowing increasing the velocity until things stall out, then lower them by about 15-20% For example I can get 30 ipm, but if there is a slight bind on the table, then they stall, so I lowered it until I can safely run full length of my machine. Hope this helps, |
| Hey thanks! that being said either we have=different boards or different instructions, as the .doc file in the supplied dvd has a picture of a different board and if I use the supplied pinouts nothing moves. By trial and error iv managed to find the step pin for X but thats it, no CW/CCW and nothing for YZA... if its not a major pain do you mind posting what pinouts they sent you? Im worried the hunt and peck approach to finding these pins is going to take a while |
I found this link on google, http://www.google.ca/url?sa=t&source...gIOMz6rJjGHAfQ it is a little different than mine, is it the same as yours. |
| Need Help!- tb6560 with usb adapter? | jan4321 | Stepper Motors and Drives | 4 | 08-30-2011 05:28 PM |
| Mac 3 setup for TB6560 controller board | davidarf | General CNC (Mill and Lathe) Control Software (NC) | 1 | 07-27-2011 02:31 AM |
| TB6560 Clone?? | circuitz | Stepper Motors and Drives | 0 | 10-25-2010 01:26 PM |
| tb6560 help me!!!!!!!! | AvioP | Stepper Motors and Drives | 1 | 08-02-2010 03:06 PM |
| TB6560 Board. | Telly | Stepper Motors and Drives | 0 | 07-26-2010 12:32 PM |
