Old 12-27-2010, 09:11 PM
BrassBuilder is on a distinguished road
Parallel port issues...
I just installed a Rosewill RC-302 parallel port card. I was only getting 4.4v and 3.4v out of the on-board parallel port. I am now getting 5v where I need it.
Anyway, I got the driver installed and I looked up the address and it has this listed:
Input/Output Range 2070-2077
Input/Output Range 2068-206F
Input/Output Range 2060-2067
Input/Output Range 2058-205F
Input/Output Range 2050-2057
Input/Output Range 2040-204F
Interrupt Request 21
In Mach3, I enable LPT2...but what address do I put in the block? It has 0x278 in there right now which really does match up with much of the above.
Do I check the block to enable pins 2-9 as inputs?
I am running Windows 2000.
I cannot find to see what the card is setup as....ECP....
And...there is a Microsoft RawPort driver that is missing once I install this card. Any idea what that is? Google is not telling me a lot.
Mike
Old 12-28-2010, 08:06 AM
Tweakie's Avatar
Tweakie is on a distinguished road
From that info the LPT2 port address to enter into Mach would. I think, be 0x2070 or 0x2040 (not sure which).
Tweakie.
CNC is only limited by our imagination.
Old 12-28-2010, 09:37 AM
According to the Mach3 manual, I am supposed to use the top address.
On my other computer, the port address is 0378 and in Mach it is 0x378.
So....do I use 2x070 or 0x2070? From what I have been reading, the leading 0 gets dropped and since i don't have a leading 0, I suspect your answer is correct....0x2070.
Just want to make sure though.
Mike
Old 12-28-2010, 10:46 AM
johnohara's Avatar
johnohara is on a distinguished road
The default address for LPT1 is 0x378. I believe the default address for LPT2 is 0x278.
Under Windows XP, the address information is found under the hardware manager. Hardware Manager is under the System icon on the Control Panel.
Win 2000 may be a little different but not by much.
~John
Old 12-28-2010, 11:46 AM
ger21's Avatar
Try watching the installation video, Art shows you what number to use. And I think you can just enter 2070. But check the video.
Old 12-29-2010, 08:50 PM
Tweakie.
0x2070 is.
Thanks. I got my new card working with the system
Mike
parallel port or parallel universe bruno34 Taig Mills & Lathes 5 04-15-2009 10:58 AM
Parallel Port issues on Bridgeport vmc 760/22 corduroy Bridgeport and Hardinge Mills 1 09-13-2008 06:50 PM
USB to Parallel port? TheDude Hobbycnc (Products) 6 03-24-2008 11:04 AM
Parallel port Aldoseri BobCad-Cam 11 03-13-2006 10:10 AM
Parallel Port Shanghyd Computers and Networking 1 11-22-2004 11:56 AM
