Old 12-18-2010, 03:27 PM
studysession is on a distinguished road
help needed
Hi -
I am not new to CNC but I am new to setting up some of these settings in Mach3. How do I calculate steps per inch in Mach3? I am not getting accurate when I use the setup wizard thing.
I have a DIY cnc machine
1/2" 10 tpi ACME screw rods.
My board is set to FULL step
Direct drive
Kelling KL23H276 bipolar stepper motor
NEMA 23
Dual Shaft Front shaft=1/4" x 7/8" Back shaft= 1/4" x 5/8"
200 steps per revolution
1.8 degrees per step
No. of wires=8
Bipolar series Volts=3.86, Amps=2.1, Ohms=1.84, Holding torque=2.0 Nm. 0r 282 oz-in
Bipolar parallel Volts=1.93, Amps=4.2, Ohms=.0.46 Holding torque= 2.0 Nm. or 282 oz-in
THANKS
ID:	121661   Click image for larger version
Please check out my CNC blog
http://cncinside.com
Old 12-18-2010, 07:41 PM
awerby is on a distinguished road
Sounds like 2000 steps per inch to me
Multiply your threads per inch (10) times the microstepping factor (1) times the number of steps per revolution of the motor (200) and you get 2000 steps per inch. Try that, then tell the machine to move an inch and see what happens. (Remember to "save axis settings" or it won't remember what you put in the box...)
Andrew Werby
ComputerSculpture.com — Home Page for Discount Hardware & Software
Old 12-18-2010, 07:58 PM
Thanks!!
Fem help needed plz extrasolar UG NX 0 10-02-2010 12:38 PM
Help needed rahim Bending, Forging,Extrusion... 1 06-05-2010 09:12 PM
Space needed behind TM-1 needed? helocat Haas Mills 9 05-20-2010 08:31 AM
help needed anil RC Robotics & Autonomous Robots 0 06-18-2007 06:52 AM
New VMC needed Scott_bob General Metal Working Machines 1 08-22-2004 12:19 PM
