Old 07-12-2005, 10:19 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Mach and the Joystick
I was using a joystick today and it works very well, my question is can I assign the buttons?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 07-12-2005, 11:08 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
Use the Key grabber found in the mach2 folder. This will enable you to assign the buttons to perform functions.
Old 07-12-2005, 11:54 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
On the Yahoo Furums mach2, there is a joystick.exe file.. here is the text doc for it, looks like predefined keys already.
Play station 2 controller.. 2 sticks.. 4 triggers, POV hat buttons, select, Start, 4 function buttons on right
Using a smart joy adapter to usb. Program works with Windows directx reads.
This may work with other usb joysticks.
Much easier for a disabled person to use a stick they can sit in thier lap.
Software uses a windows common dialog procedure to transfer the keystrokes into the mouse buffer and the keyboard buffer
Free software, send a thankyou note to ibewgypsie@hotmail.com if you like.
Controls
Left Stick is Mouse position
Right stick is bottom block positions, not used yet.
POV is keyboard 4 Direction arrows.
Left bottom trigger is Left mouse click
Right bottom trigger is right mouse click
Top left trigger is right mouse click
Top Right trigger is the ENTER key..
Top Rt button is page up
Bot rt button is page down
Left Rt button is backspace
Right rt button is space
Select button is tab key (select entry)
We can get it loaded to Ynnebs forums for mach 2/3/4
Joe
Joystick to Keyboard mapping software dwwright Kellyware CAM 1 12-25-2007 07:03 PM
In-line opensource joystick mvaughn Open Source Controller Boards 23 01-31-2005 01:42 PM
starting offer usb joystick & keyboard pendant da21 Open Source Controller Boards 7 01-11-2005 02:38 PM
Joystick Control Sanghera DIY-CNC Router Table Machines 11 06-15-2004 11:39 PM
using PWM from mach 2 Cecil General Electronics Discussion 1 08-28-2003 10:11 AM
