Old 12-14-2010, 05:53 PM
Romper is on a distinguished road
cut location on material
WE are using Mach3 and creating cut paths in cut 2d from Alibre files. We are having trouble with the cut out location on the material being changed from cut 2d to mach3. When the code is loaded into mach3 the cutouts are moved to one side of the material instead of centered where we had them in cut 2d. thanks for any help.
Old 12-14-2010, 06:00 PM
ger21's Avatar
Make sure you have your origin (0,0) in Cut2D set the same as you're 0,0 in Mach3. There's no way that the cutting position is changing.
Old 12-14-2010, 06:13 PM
origins are 0,0,
Our origins our 0,0 and mach3 is starting in the corner were we want it to but the parts are pushed all the way to one side of the material and we have them centered in the material in in cut2d. We are using mm in cut2d but we are using inches in Mach3, our post possessor settings are mach3 inches. The parts are the right size just positioned wrong in the material.
Old 12-14-2010, 06:35 PM
ger21's Avatar
Why?? That could be causing the problem, but I don't know for sure.
Simplest thing to do is generate code for a simple square in Cut2D. Look at the g-code, and see if the coordinates match what's in Cut2D.
If you have you're origin set up correctly in Mach3, then you're problem is with Cut2D. Mach3 just reaads the g-code and does what it tells it to.
Old 12-15-2010, 10:46 AM
Material size in gcode
Where in the gcode is the material size specified?
Old 12-15-2010, 10:54 AM
ger21's Avatar
It's not. The gcode specifies absolute coordinates. The material on your machine needs to be in the correct location relative to the location in Cut2D.
Old 12-15-2010, 06:19 PM
switching to metric
our problem was in our cad drawing not mach3 or cut2d, total flailing on my part, thanks for all the help. What is the best way to configure Mach three to metric? All the motor tuning numbers we have are in inches. I did change the units to mm on the settings page and that seemed to work but it changes back every time I restart mach3. I work exclusively in metric so I don't want any confusion. Thanks for all your help I am a total rookie with cnc.
Old 12-15-2010, 07:47 PM
ger21's Avatar
Config > Select native Units.
You'll need to redo the motor tuning in mm's. Be sure to close and restart, both after setting Native Units, and after motor tuning.
Getting the X and Y of my First CAM location vpcnc BobCad-Cam 4 06-22-2007 09:34 AM
What is the X & Y Location Joe Crumley Commercial CNC Wood Routers 3 04-09-2007 12:42 AM
Map your location Rekd CNCzone Club House 20 10-20-2005 09:49 PM
location mocnc DIY-CNC Router Table Machines 15 04-08-2005 04:12 PM
location? fastolds Surfcam 11 12-02-2004 01:58 AM
