| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Hello All, I am getting ready to install my home switches and relays and was wondering what is the best or normal spot to put them. Right now I have machine zero in the middle of X, Y and Z. In reading up on how Mach3 hunts for home, it looks like one needs to position the zero spots almost at max -X and -Y. Any advice would be appreciated. Mark |
| Otherwise, it will not know in which direction to go to hit the home switch. These programs are setup to only go in one direction for home either the plus direction or the minus direction (notice I did not say position) as the homing routines are ignorant of position until it hits the home switch. For instance, my X homes in the negative direction and the Y and Z in the positive direction.
__________________ Art AKA Country Bubba (Older Than Dirt) |
| Having home position at one end of axis travel is certainly the easiest way to do it. However it is not the only way. On one of my machines (mill) I have the X axis home switch at the centre of travel. It is just a convenience thing. If the home switch is set up correctly then Mach will know which way to travel when seeking the home switch. However the switch setup is more complex. It involves an actuation method that activates the switch and holds it active all the way to one end of travel. For this reason it really needs non contact type switch. (Prox or opto) Mach can be set to seek home in one direction if the switch is active, and the other direction if it is not active. I say again, much easier just to have switch at one end. ![]() Greg |
So, you can have you're home switches at the end, to make it easy, and still have you're machine coordinates in the middle. You can also modify the homing procedure to go to machine zero after homing.
| Home Switches???? | whitehedr | Benchtop Machines | 21 | 07-08-2010 09:29 PM |
| Home switches | whitehedr | Benchtop Machines | 8 | 12-21-2009 12:02 PM |
| The relationship of limit switches to home switches. | MikeAber | General Electronics Discussion | 4 | 11-04-2004 01:28 PM |
| Limit switches and home switches | viktorcnc | TurboCNC | 2 | 08-03-2004 06:11 AM |
| Home switches and limit switches. | ynneb | General Electronics Discussion | 5 | 04-08-2004 05:32 PM |
