Old 12-05-2010, 10:08 AM
adamchapman is on a distinguished road
Trouble with printer port settings
My old laptop just died and Im trying to use another very old laptop to control my machine now.
I know the printer port must be working, because when I change any settings to the port "LPT1"in device manager, I hear my stepper motors clunk.
However, Even though I have the correct port assigned in Mach (0x378), and have set the correct pin numbers for my stepper driver board, The motors are not recieving any signal on command from Mach3.
I don't know if it has anything to do with the "interupt" settings for the port in XP's device manager, or if the problem is with a setting in Mach3 itself.
Any help is hugely appreciated.
Old 12-05-2010, 02:22 PM
bobsch's Avatar
bobsch is on a distinguished road
Double check to make sure your parallel port is set for EPP in the laptop's BIOS.
Bob
"Bad decisions make good stories."
Old 12-05-2010, 08:49 PM
Dorsal is on a distinguished road
Have you run the "Drivertest.exe" file, located in the root directory of Mach? Is the signal clean?
Are you sure you didn't assign the "step" pin as the "direction" pin, and vice-versa?
Old 12-09-2010, 01:20 PM
MarshaJ847 is on a distinguished road
In the Device Manager make sure you have changed the Computer setting from ACPI PC to Standard PC and reboot, this will bypass some of the laptops power saving and timing features that can interfere with Mach 3
Marsha
My current pc has no printer port, what would you do? slashmaster Benchtop Machines 6 01-08-2010 12:23 PM
printer port to usb mocnc DIY-CNC Router Table Machines 2 03-02-2009 02:30 AM
Printer port problems tehMadmachinist Mach Software (ArtSoft software) 11 03-15-2007 09:10 PM
printer port tester smarbaga General Electronics Discussion 1 12-10-2005 11:57 AM
printer port? replicapro General CAM Discussion 2 11-26-2004 03:37 PM
