Old 11-19-2010, 09:06 PM
webgeek is on a distinguished road
Mach 3 w/Coolant and Spindle Failing
This was solved by the wonderful JoeBean in the other forum here (thanks Joe!):
http://www.cnczone.com/forums/novako...ant_issue.html
Hi all; I posted this question in the Novakon forum a few hours ago but I'm not sure it's the right place so I'm posting the same question here. Sorry for the cross post.
I finally set up my new mill to do flood coolant after milling for a few dozen hours without it. The problem is, as soon as I plugged in the pump (I think) the spindle stopped working in all my gcode programs. I can manually kick the spindle off with Mach still but when I run the gcode, it immediately shuts down again. Now the wierd stuff, if I go into Spindle Control in Mach 3 and check "Disable Flood/Mist Coolant" all goes back to normal with my programs but clearly coolant isn't working at that point. Basically, I can get coolant working via turning it on and off in the diagnostics pane but it kills the spindle or I can have everything run perfectly but coolant has to be disabled.
My question is two fold - what the heck is wrong and how do I fix it?
Thanks in advance. I have a huge amount of milling to do this weekend and I'd REALLY like to get the coolant working so I can use my better end mills. Thanks much for help!
-Mike
Problem- Spindle inverter failing? rickt395 Fadal 9 10-06-2010 10:05 AM
pin driver chip keeps failing. Crawler374 Hobbycnc (Products) 8 01-07-2010 11:56 PM
Need Help!- Profiling program failing Turk88 Haas Lathes 11 04-21-2009 10:37 AM
Please help! Z-axis transistor keeps failing when I turn spindle on jderou Bridgeport and Hardinge Mills 1 03-27-2009 07:09 AM
Is our education system failing us in the USA? CJL5585 CNCzone Club House 42 02-26-2007 09:06 AM
