| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
If I have Soft Limits turned off and hit a limit switch it triggers an E-Stop, as it should. Using manual over ride I can jog off the switch but as soon as the axis moves a fraction of an inch and the limit switch closes, it triggers another E-stop. I then have to hit Reset again, and then can move away as normal. Is this double limit switch triggering of an E-Stop normal? Or is there a setting I've missed? |
| Increase the debounce to 500. Are you using mechanical limit switches? They can bounce on transition and retrigger the E-S Best way to fix this is make the soft limits work correctly, then there will be no problems. E-S is EMERGENCY STOP. Use it for emergencies, as it was intended.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Limit switch replacement with proximity switch? | Normsthename | Bending, Forging,Extrusion... | 3 | 07-11-2009 10:38 AM |
| The reset switch | chrugel | UHU Servo Controllers | 1 | 01-29-2009 12:36 AM |
| On an OT control, hitting the reset button | g-codeguy | Fanuc | 3 | 06-13-2007 11:21 PM |
| Limit Switch / Home Switch in Software | Sanghera | General Electronics Discussion | 6 | 11-01-2004 05:58 PM |
