| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I am new to CNC and Mach3. My DIY CNC router is nearing completion and the motors are up and running, with one hitch. The X Axis is dual drive, the stepper on one lead screw is driven from the X port on the Gecko G540, the other stepper is driven from the A port, which is configured to slave to the X. When jogging, or running G code, both motors are synced perfectly, but when when I push the REF ALL HOME button, only the X axis motor runs, the A motor stays put, causing the gantry to rack, then stall, and make a whole lot of nasty sounds before I can hit the E-Stop! What setting(s) am I missing? |
| If you only have one home switch, then, in General Config, check "Home Slave with Master Axis".
| any issue with slaved axis? | multiplex | Viper Servo drives | 5 | 01-22-2010 09:06 PM |
| How do I compare a slaved motor? | MetropolisCNC | DIY-CNC Router Table Machines | 2 | 06-26-2009 04:09 PM |
| Need Help!- Adding a slaved X axis | t140nick | Mach Software (ArtSoft software) | 4 | 02-05-2009 02:05 AM |
| Need emergency help. Slaved Y still binding.. | nate | DIY-CNC Router Table Machines | 2 | 03-05-2008 06:59 PM |
| slaved motors aren't working in synch | axisdd | DIY-CNC Router Table Machines | 2 | 03-15-2006 01:59 PM |
