Old 06-26-2005, 07:48 AM
Redline's Avatar
Redline is on a distinguished road
Mach 1 x-axis will not move
I set up Mach 1 and master 5 But the x-axis will not move.I know it is not the controller or the motors,because it worked fine with turbo cnc.What do you think it might be?
Old 06-26-2005, 08:39 AM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
....it could be many many things...
try going through the configuration menu and rechecking all the pinouts setting and such..
when I first tested my motors on the table, I simply had to reverse the two power wires to one motor before it would function...this is with servos and gecko drives....simply reversing the power wires to the motor does not reverse the motor direction....that is done in the setup DIR-hi/lo setting.
Old 06-26-2005, 08:47 AM
ger21's Avatar
Mach1 will only run on Win2K or XP. Master5 will only run on Win98 or ME. Did you install them both on the same computer? If so, 1 of them shouldn't work at all. Are you saying the other axis work, just not the X?
Most likely it's a setting issue. Does the motor lock up when power is applied?
Old 07-05-2005, 12:01 AM
Redline's Avatar
yes they were both installed on the same computer win xp.i have Mach2 running fine but i would like to use an older more diposable computer running master 5.yes the other axis did work.
Building a CNC router HomeCNC CNC Wood Router Project Log 230 10-18-2009 06:56 AM
4020 4th axis problems little bubba Fadal 3 06-13-2005 09:08 PM
Speed how fast an axis can move? jlagran he General CNC (Mill and Lathe) Control Software (NC) 0 01-04-2005 10:05 PM
how does mach 2 and similar programs know how far to move ? Apples General CAM Discussion 1 05-11-2004 02:43 AM
Retrofit: Central Mach. CNC 3 axis Mill Rekd General Metal Working Machines 6 02-06-2004 04:19 PM
