Old 10-11-2010, 11:15 AM
telah is on a distinguished road
Limit switch and keyboard emulator
Hello all,
In the mach3 manual it is mentioned that you can use a keyboard emulator for your limit and home switch, unfortunately they do not explain how to do it I have tried many thing and I just can't figure how to do it.
I tried keygrabber provided with mach3 so i can assign a function but there is no function for the limit switch and home switch.
the keyboard emulator I have is a GP-Wiz from groovygamegear I reused from an old arcade project.
I do know there is a delay using a keyboard emulator but it mostly for testing and I am a bit short on input pin on my breakout board.
Thanks.
Old 10-11-2010, 11:32 AM
ok found my solution :P
for some reason on my cnc machine there was no emulation option on the port and pin setup, reinstalled the latest version and now everything is there o.O
Limit switch replacement with proximity switch? Normsthename Bending, Forging,Extrusion... 3 07-11-2009 10:38 AM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
Is it possible to use the home switch as the limit switch as well? Darc Mach Software (ArtSoft software) 2 10-23-2005 12:50 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
