| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Whats the best way to combat noise in my z home limit switch wiring on Mach3. I am running a probotix breakout board and the wires are giving faults signals to my THC300. I tried bumping up the debounce already but it did not work. Will ferrite beads work? |
| I had similar problems with noise on my limit switch wires, even when they were shielded. My solution was to put a .01 ceramic capacitor and a 1 mfd electrolytic capacitor in my controller, right at the point where the wires attached to the circuit board. The capacitors are between the wire connection block and ground on the circuit board. You can get these very small parts at a Radio Shack store. I can now run a very low debounce value as well, no more false signals to the board. George |
There is a kind of software fix, it worked for 2 of my axes but not for the third one, the one i think has most noise. If you are in Mach3 go to Config - General Config and find a textbox with the debouncing number, by default it's 0, try setting it a value between 500 and 10000 and tell me if that does it for you |
#10
| Al.
| Wiring Limit, Home and E-Stop Switches | gpraceman | Safety Zone | 53 | 05-01-2012 08:40 AM |
| Wiring home and limit switches | Hack | General Electronics Discussion | 7 | 01-24-2009 03:47 PM |
| Home and limit wiring on centurion 4 | ozturbo | Milltronics | 1 | 07-03-2008 01:55 PM |
| Limit & Home Switch Wiring? | Willyb | Gecko Drives | 0 | 10-17-2005 04:02 PM |
| Home limit switch wiring. | DAB_Design | Mach Software (ArtSoft software) | 5 | 12-23-2004 05:48 AM |
