| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Iam currently using one computer to run my home built router. I would like to also use this computer with mach 3 on it to run a seperate small lathe at various times. I realize that accordingly to the license I can do this ( but not both Machines at the same time). Because one machine will be using mach mill and the other mach lathe. In changing back an forth I would have different configurations for both systems. Would I lose these configurations and have to reset after each swap? Eventually I will dedicate a seperate computer to the lathe. One other item is that the lathe will have its one power supply, breakout board, drivers, and dedicacted motors. Thanks JohnD |
You just need to generate a separate "Profile" for each different machine, and call it by a different name. This results in 2 different XML files being stored in the Mach3 folder. When you start up, using Mach3 Loader, you'll see both of them; just pick the one that's right for the machine you're using at the time. Andrew Werby www.computersculpture.com |
| Dual Steppers or Timing Belt for Dual X-axis? | GEBrown | Linear and Rotary Motion | 3 | 05-27-2010 11:45 AM |
| Just IN- EUROTECH Dual and Tripple Turrets Machine | EUROTECH | Product Announcements & Manufacturer News | 0 | 09-21-2009 08:50 PM |
| Dual NC controls within a single machine | Jim Shaper | General Metal Working Machines | 14 | 06-01-2009 12:02 AM |
| Dual Z axis and Dual Spindle | Adamj12b | Mach Software (ArtSoft software) | 3 | 08-28-2008 03:15 PM |
| Asynchronous control of a dual head machine? | microjet2 | G-Code Programing | 4 | 02-14-2008 12:55 PM |
