Results 1 to 5 of 5
Thread: Motor reverses direction on its own from keyboard
    Dec 2007
    I'm not sure if this is a Mach3 issue. I've looked through the manual and I am not finding an answer. Here is what is happening:
    I am running a Pacific Scientific NEMA 42 motor on a lathe conversion. If I press the arrow key to jog the carriage over, let up the key, and then press it back down, about 50-75% of the time, the motor will rotate in the opposite direction. If I let up the key, press down, it will usually go back to the original direction. Sometimes I have to press the key 2-3 times before it will change directions.
    I ran this from the lathe module. I tried to run the motor from the mill module and it does the same thing.
    Any ideas on this?
    Mike
    Dec 2003
    Mason, Ohio
    Mike,
    I am experiencing the same problem with my z-axis. I have a Gecko drive (gel210a) on this axis. Any answers or solutions yet?
    Adrian
    Oct 2005
    Yes. I had the same problem. it was a broken solder joint under some shrink wrap. The contact wasn't always being made and was causing very strange and erratic behavior on my Z axis. Naturally it only happened at some Y positions (on a router) as the Z axis motor cable was moved back and forth. Geckos are so good that any other drive that'd blow from the intermittent loads just make them keep the motor moving even if it is + when you want -. Check your cables and all connections.
    Dec 2007
    Interesting. I haven't found the answer to my problem yet, but I will definately recheck the connections. I soldered all the wires together or to individual connections.
    I just got a Contour Shuttle Pro in and I was going to hook that up and see if the problem still exists. I'll post back what I find.
    Mike
    Dec 2003
    Mason, Ohio
    Mike,
    Thanks! I will check my connections tonight.
    Adrian
    1. Reverse Motor Direction
      By electric2u in forum Mach Software (ArtSoft software)
      Last Post: 02-19-2010, 12:46 AM
    2. Need help with motor direction
      By marzetti in forum Automation Technology Products
      Last Post: 11-30-2009, 09:59 PM
    3. Motor Reverses w/o Command
      By buz0340 in forum General Electronics Discussion
      Last Post: 03-25-2009, 10:02 AM
    4. Motor Direction
      By Ken Bond in forum Phase Converters and VFD
      Last Post: 11-20-2007, 07:22 AM
    5. motor direction
      By sixpence in forum Mach Software (ArtSoft software)
      Last Post: 12-28-2004, 11:15 PM
