Old 08-30-2010, 03:34 PM
lilimike is on a distinguished road
Z axis is mysterious
I don't know where to look anymore, here is my problem:
First off I am at my first steps in generating something with my home made CNC. I was able to test with engraving a picture using Microcarve V4 and the results were almost fair to good, enough to know it is 98% accurate.
Now using Lazycam I generated text and posted G-Code and started to engrave on Plexiglas at a deepness of 1/16" but at or near the third letter the Z axis starts going down to the point where it goes through the Plexiglas 3/16"
This is my code up to where I start having a problem:
Code:
N10 (Default Mill Post)
N15  G91.1
N20 G0  Z0.2000
N25 M3
N30  X0.1407  Y0.3134
N35  Z0.1000
N40 G1  Z-0.1000  F8.00
N45  X0.1400  Y0.2650
N50  X0.1393  Y0.1890
N55  Y0.1329
N60  X0.1407  Y0.0149
N65  X0.1563  Y0.0142
N70  X0.2544  Y0.0163
N75  X0.2721
N80  X0.2750
N85  X0.2778
N90  X0.2800  Y0.0156
N95  X0.2821  Y0.0142
N100  X0.2835  Y0.0135
N105  X0.2842  Y0.0121
N110  X0.2849  Y0.0099
N115  X0.2856  Y0.0078
N120  X0.2849  Y0.0064
N125  Y0.0050
N130  X0.2842  Y0.0036
N135  X0.2835  Y0.0028
N140  X0.2828  Y0.0021
N145  X0.2814  Y0.0014
N150  X0.2800  Y0.0007
N155  X0.2785  Y0.0000
N160  X0.2778
N165  X0.2771
N170  X0.2757
N175  X0.2750
N180  X0.2736
N185  X0.2714
N190  X0.2700
N195  X0.2679
N200  X0.0000
N205  Y0.0867
N210  X0.0007  Y0.1407
N215  Y0.2011
N220  X0.0000  Y0.2935
N225  X0.0007  Y0.3134
N230  X0.1227
N235  X0.1407
N240 G0  Z0.2000
N245  X0.3725  Y0.3318
N250  Z0.1000
N255 G1  Z-0.1000
N260  X0.3605  Y0.3304
N265  X0.3505  Y0.3276
N270  X0.3427  Y0.3240
N275  X0.3363  Y0.3197
N280  X0.3320  Y0.3141
N285  X0.3292  Y0.3077
N290  X0.3285  Y0.2999
N295  X0.3292  Y0.2927
N300  X0.3320  Y0.2864
N305  X0.3363  Y0.2807
N310  X0.3427  Y0.2764
N315  X0.3505  Y0.2729
N320  X0.3605  Y0.2700
N325  X0.3725  Y0.2686
N330  X0.3860  Y0.2679
N335  X0.3924  Y0.2686
N340  X0.3995
N345  X0.4059  Y0.2693
N350  X0.4116  Y0.2700
N355  X0.4166  Y0.2714
N360  X0.4216  Y0.2729
N365  X0.4265  Y0.2750
N370  X0.4308  Y0.2764
N375  X0.4344  Y0.2792
N380  X0.4379  Y0.2814
N385  X0.4408  Y0.2842
N390  X0.4436  Y0.2871
N395  X0.4450  Y0.2899
N400  X0.4464  Y0.2935
N405  X0.4472  Y0.2963
N410  X0.4479  Y0.2999
N415  X0.4464  Y0.3077
N420  X0.4436  Y0.3141
N425  X0.4386  Y0.3197
N430  X0.4322  Y0.3240
N435  X0.4237  Y0.3276
N440  X0.4130  Y0.3304
N445  X0.4003  Y0.3318
N450  X0.3860
N455  X0.3725
N460 G0  Z0.2000
N465  X0.3285  Y0.2508
N470  Z0.1000
N475 G1  Z-0.1000
N480  Y0.2423
N485  Y0.1982
N490  X0.3299  Y0.1592
N495  X0.3285  Y0.0846
N500  Y0.0000
N505  X0.4457
N510  Y0.0206
N515  X0.4443  Y0.0682
N520  X0.4457  Y0.1528
N525  Y0.2082
N530  X0.4472  Y0.2444
N535  Y0.2508
N540  X0.3285
N545 G0  Z0.2000
N550  X0.5830  Y0.3134
N555  Z0.1000
N560 G1  Z-0.1000
N565  Y0.3020
N570  Y0.2210
N575  Y0.1855
N580  X0.5823  Y0.1215
N585  X0.5830  Y0.0085
N590  Y0.0000
N595  X0.4658
N600  Y0.0107
N605  Y0.0469
N610  Y0.1130
N615  X0.4672  Y0.1997
N620  X0.4665  Y0.2466
N625  X0.4658  Y0.2977
N630  X0.4665  Y0.3134
N635  X0.5650
N640  X0.5830
N645 G0  Z0.2000
N650  X0.6446  Y0.3318
N655  Z0.1000
N660 G1  Z-0.1000
N665  X0.6326  Y0.3304
N670  X0.6226  Y0.3276
N675  X0.6148  Y0.3240
N680  X0.6084  Y0.3197
N685  X0.6041  Y0.3141
N690  X0.6013  Y0.3077
N695  X0.6006  Y0.2999
N700  X0.6013  Y0.2927
N705  X0.6041  Y0.2864
N710  X0.6084  Y0.2807
N715  X0.6148  Y0.2764
N720  X0.6226  Y0.2729
N725  X0.6326  Y0.2700
N730  X0.6446  Y0.2686
N735  X0.6581  Y0.2679
N740  X0.6645  Y0.2686
N745  X0.6716
N750  X0.6780  Y0.2693
N755  X0.6837  Y0.2700
N760  X0.6887  Y0.2714
N765  X0.6937  Y0.2729
N770  X0.6987  Y0.2750
N775  X0.7029  Y0.2764
N780  X0.7065  Y0.2792
N785  X0.7100  Y0.2814
N790  X0.7129  Y0.2842
N795  X0.7157  Y0.2871
N800  X0.7171  Y0.2899
N805  X0.7185  Y0.2935
N810  X0.7193  Y0.2963
N815  X0.7200  Y0.2999
N820  X0.7185  Y0.3077
N825  X0.7157  Y0.3141
N830  X0.7107  Y0.3197
N835  X0.7043  Y0.3240
N840  X0.6958  Y0.3276
N845  X0.6852  Y0.3304
N850  X0.6724  Y0.3318
N855  X0.6581
N860  X0.6446
N865 G0  Z0.2000
N870  X0.6006  Y0.2508
N875  Z0.1000
N880 G1  Z-0.1000
N885  Y0.2423
N890  Y0.1982
N895  X0.6020  Y0.1592
N900  X0.6006  Y0.0846
N905  Y0.0000
N910  X0.7178
N915  Y0.0206
N920  X0.7164  Y0.0682
N925  X0.7178  Y0.1528
N930  Y0.2082
N935  X0.7193  Y0.2444
N940  Y0.2508
N945  X0.6006
N950 G0  Z0.2000
N955  X0.9112  Y0.1606
N960  Z0.1000
N965 G1  Z-0.1000
So I figured my Z axis is missing some steps therefore I ran some test using this code:
Code:
F8
G20 G90
M98 P1234 L50
M30 (stop)
O1234
G1 z-0.1
G1 z0.2
G1 z0
M99
But after the 50 loops, Z is at zero and accurate.
What can be my problem?
Thanks for any help.
Mike
Old 08-30-2010, 06:16 PM
ger21's Avatar
You're losing steps on the G0 moves, and your testing with much slower G1 moves.
Old 08-30-2010, 06:40 PM
Yes you are right, I tested again replacing G1 with G0 in my test code and I am loosing 0.4073 after 50 loops
Why am I loosing steps on the G0 moves and not on G1?
Do I have to slow down the velocity and play with acceleration?
Thank you
Mike
Old 08-30-2010, 07:06 PM
ger21's Avatar
Cut the acceleration in half.
Old 08-31-2010, 10:01 AM
My acceleration was set to 2, I tried to set it at 1 and also at 4 but still got the same results.
I had previously started another thread and I guess I should have kept it going but I figured I had a different issue and this is why I started this thread.
Actually I am starting to think my issue is I am getting old because I keep running into different problems and this all doesn't seem logical to me, it looks like there is no specific setup procedure that applies to everyone.
So going back to that other post you had suggested I go from 35KHz to 25KHzs which I did but it made things worse however I tried 40KHz and all was going right (until this present thread)
So now it is getting complicated therefore I have started from scratch. The seller of my driver board suggests I use 35KHz so I set 35KHz. Note that I have tried the drivertest and I get "System Excellent" from 25KHz up to 100KHz.
I have used the Axis calibration "Set steps per unit" on the settings screen and got steps per = 31659.90338 for accurate distance travel.
I set Acceleration to 5 and I tested velocity for maximum which was 33. Going to 34 started going slower so I reduced by 20% and set velocity to 27.2 and reduced acceleration to 2.
Now if I run this code using 9 loops, its all good:
Code:
F8
G20 G91.1
M98 P1234 L9
M30 (stop)
O1234
G0 z.5
G0 z0
M99
If I run it 50 loops, looking at the diagnostics screen while Queue Depth cycles from 20 to 19 and back to 20 it is also all good until the computer beeps and at the same time as the Queue Depth cycles from 19 to 18 and keeps going down. At that moment the stepper screams and looses about 0.23 worth of steps.
I changed Acceleration from 2 to 1 and also tried 4 with no apparent improvement. I also tried reducing velocity to 20 but still the same problem.
My steppers have 4 wires, I've tried inverting each set of wires going to coils with no change.
Is there anything I can test perhaps with an oscilloscope?
Thanks again for any help and patience
Mike
Old 08-31-2010, 05:51 PM
Dorsal is on a distinguished road
Check for a loose setscrew on the z-axis drive couplers. If there are none already, file some flats on the shafts and be sure the setscrews engage those flats.
Old 08-31-2010, 06:10 PM
There is nothing loose. The missing steps can be heard when the stepper screams as soon as the computer beeps when the Queue Depth is no longer buffered.
I can set my code to do 100 loops and it will do at least 80 without loosing steps but almost near the end the problem happens.
Mike
Old 08-31-2010, 06:46 PM
ger21's Avatar
How fast is your PC, and what does the drivertest look like? Is it a perfectly flat line, or are there spikes in it?
Old 08-31-2010, 07:45 PM
I have a Pentium 4 processor 3.4GHz with 1 GB of RAM
I do see a few spikes in the drivertest
With 35KHz it looks like this:
And with 100KHs it looks like this:
I do not understand much of what the drivertest shows other than the status "System excellent"
Mike
Old 09-01-2010, 11:26 AM
UUU UUU is offline
UUU is on a distinguished road
Try doing your loops with G0 in one direction (say up) and G1 the other way (down). If you G0 both ways you may be losing the same number of steps both ways (OK the Z is special because up is harder than down). But if you lose steps on the rapid, but not on the slow, it will show up. Also this mimics the way the Z is moved in your engraving code.
  #11   Ban this user!
Old 09-01-2010, 01:11 PM
mactec54 is on a distinguished road
lilimike
Try changing the G91.1 to G90 this may make the control work for you better as well
Mactec54
  #12   Ban this user!
Old 09-01-2010, 01:31 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Voltage= speed. Double the Voltage, double the speed. Are you running your 52V motors on 12V? If so, try using the 24V PSU again. It should double your rapid speed--and stop the missing steps problem at 33IPM.
Maybe you should think about upgrading to a G540.
http://kelinginc.net/GeckorDriver.html
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
Need Help!- Mysterious tool SIRSEBAST General Metalwork Discussion 11 04-01-2009 10:58 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
Mysterious plastic sp1nm0nkey General Metalwork Discussion 2 12-04-2007 08:46 AM
Mysterious "W" series NSK Ballscrews NC_jimbo Linear and Rotary Motion 2 04-15-2007 12:38 AM
Mysterious Y axis move before tool change daking Fadal 2 11-27-2006 11:38 AM
