Old 06-05-2005, 01:09 PM
metalhacker is on a distinguished road
Mach2 driver enable connection
I want to configure my controller to run Mach2 but I need a port pin
for "enable" on each axis. How do I connect these to MAch2 as their
pin configutration does not allow for this?
Old 06-06-2005, 01:59 PM
Art Fenerty's Avatar
Art Fenerty is on a distinguished road
Hi:
Mach2 has 6 enables, one for each axis. YOu simple turn on the enable 1 - Enable x and they will go active to enable each axis which is turned on in the config..
(Mach3 also has a current reduction pin you could use if required...)
www.gearotic.com
Art Fenerty
4 Channel Stepper Driver Which One! dewayne General Electronics Discussion 2 07-08-2004 09:47 PM
Mach2 Faro Arm Inverse Kinematics vacpress General CAM Discussion 7 05-28-2004 09:14 AM
G Code and Mach2 InventIt DIY-CNC Router Table Machines 8 03-13-2004 01:46 PM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 01:18 AM
