Old 06-04-2005, 09:56 AM
Cyclone's Avatar
*Registered User*
Cyclone is on a distinguished road
Mach2 Help
ok....tried everything so next step is to ask someone who actually knows.
using Geckos 201's and Mach2 mill....controller box hooked up to steppers have great speed on motors and everything works like it should (bench testing motors, not on machine).
I drew a simple outline of what I am planning of cutting (in Plastic) loaded the g code and wow 15+ minutes to cut? the piece is only 6 inches long by 4 inches wide! started to play around with settings on Mach2 but do not want to tweak things that I shouldn't be messing with...
The question is....how do I speed up the actual cut cycle in Mach2? I estimated a half inch per second is my target. Are there any experts out there can help me here?
Old 06-04-2005, 10:10 AM
DAB_Design is on a distinguished road
.5" per second is 30" per minute. Is that what you have your feedrate set to in your g-code?
Dustin B.
I hear and I forget.
I see and I remember.
I do and I understand.
Old 06-04-2005, 11:27 AM
Cyclone's Avatar
*Registered User*
THANK YOU!!!!!!
I knew that posting here would be alot faster than trying to figure it out on y own!
I changed the G code F1.00 to F30.00 and the part will cut in about a minute.
Thanks again!!!!
Old 06-04-2005, 11:43 AM
No problem.
Dustin B.
Mach2 remembering position after shutdown..how does it know Moondog Mach Software (ArtSoft software) 10 02-14-2005 08:56 AM
Windows XP or Windows 2000 better with Mach2 Beezer Mach Software (ArtSoft software) 2 10-18-2004 10:08 AM
Mach2 Faro Arm Inverse Kinematics vacpress General CAM Discussion 7 05-28-2004 09:14 AM
G Code and Mach2 InventIt DIY-CNC Router Table Machines 8 03-13-2004 01:46 PM
mach2 versus EMC georgebarr Mach Software (ArtSoft software) 3 02-22-2004 11:32 AM
