Old 07-31-2010, 12:59 AM
gaffa is on a distinguished road
Question X Axis Stays Still
Hi All, my problem is when I start to run gcode through Mach3 to my machine the y + z axis work fine however the x axis won't move until I pause and restart the program.
If I don't pause the program in time the y axis goes back and forth and I end up with a beautiful straight line in the work piece. However the display on Mach3 still shows the x axis moving even when it's not?
Any ides?
Old 07-31-2010, 05:59 AM
ger21's Avatar
Possibly low voltage on the port? Maybe loose wire? What is the pulse width for the X axis, and what drives are you using? Increasing the pulse width may help.
The smoke stays inside the VFD? will gilmore Phase Converters and VFD 14 05-05-2010 07:35 AM
6TB problem. M00 light stays on and.... JohnF Fanuc 2 11-24-2008 07:39 AM
Fanuc 0M stays in MDI mode malaron Fanuc 4 08-06-2007 05:19 PM
Machine stays in NOT READY at power on!? MITYDR Fanuc 15 09-05-2006 09:39 AM
Fanuc 15-M... Spindle Off lamp stays ON cncnovice Haas Mills 11 05-11-2006 09:04 AM
