Old 06-02-2005, 05:29 AM
zcases's Avatar
zcases is on a distinguished road
Mach / geckos or DTLLC drivers
I am just beginning retrofitting two Boss5 Bports. I am planning using the Mach 2 and now selecting drives. I am aware of a successful retrofit using Mach 2, 3 geckos, and a Bob Campbell breakout. Maybe its worth following his footsteps just since its known to work.
I recently found a 4 axis 10A stepper driver from Delegrange Technology LLC. It is very attractive for cost at $150 to run 4 axes. Has anyone used this driver with Mach software? Is the Campbell breakout still required?
Also - how has Mach performed for 3d work?
Thanks in advance
Scott
Old 06-02-2005, 12:40 PM
turmite is on a distinguished road
Scott,
The first question I would ask is the 4 axis drive package microstep. Art from mach2 told me that for the program to work properly it really needs micro step drives.
As to 3d work...attached is a sample of what I do and was all carved using mach2 v6.10.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 07-25-2005, 02:36 AM
stuart76 is on a distinguished road
i bought a 4 axis board off dtllc, i have no complaints. i had to buy resistors to suit the motors which were fairly expensive. you only have the option of full step and half step. im yet to enquire about going to smaller steps. im not up to that stage yet. it was very easy to hook up and also has 4 onboard relays for spindle and coolant ect.. the guy i communicated with was more than helpful, always responded quick and in good detail. im happy with my purchase but must admit i have no experience with any other board.
Old 01-11-2007, 07:06 PM
DTLLC is on a distinguished road
Thanks Stuart76
I hope you are having fun with the machine. Mach 2 and Mach 3 will run DTLLC.COM boards without a hitch you do not have to get a microstepping drive. You need to set the pulse width and direction prechange to 5uS and you will be good to go.
Dave
Need Mach 2 configuration help for Sherline 5410 wilit Mach Mill 14 01-15-2010 07:06 AM
Worth a Thousand Words Chunky General Electronics Discussion 41 05-29-2005 04:18 PM
Mach 2 and settings tauscnc Commercial CNC Wood Routers 4 05-25-2005 09:05 AM
Mach 2 slow on Intel Centrino P1.6 Notebook daddyhobby Mach Software (ArtSoft software) 7 03-28-2005 07:33 AM
Proper Computer and Chip for Mach 1 HomeCNC Mach Software (ArtSoft software) 12 03-17-2004 09:14 PM
