Old 07-25-2010, 07:07 AM
adamchapman is on a distinguished road
Can't find the "debounce" setting
Im having a problem with limit switches and have read that I need to increase the debounce setting.
I also read that it is under the menu Config>General, burt on my version of Mach3 there is no "general" option.
How can I alter my debounce value?
Old 07-25-2010, 08:46 AM
ger21's Avatar
You must have a very old version of Mach. It should be under Config>Logic or Config>State.
Old 07-25-2010, 09:58 AM
Ah, found it under logic. I was literally looking for an option called "general" in the config menu.
Old 07-25-2010, 10:01 AM
ger21's Avatar
Logic and State were combined into General Config several years ago.
How to find local machines shops? 'Ooops I meant "machine guys") FXC DIY-CNC Router Table Machines 3 11-22-2009 09:09 PM
setting up a lathe "A" axis eloid DIY-CNC Router Table Machines 1 07-20-2009 04:26 PM
Need Help!- Tip volt setting for ATHC "NEWBIE" Orangejbird CNC Plasma and Waterjet Machines 1 01-13-2009 02:05 PM
Where can I find Kress 3/16" and 3/8" collets? tahustvedt DIY-CNC Router Table Machines 4 01-12-2009 12:59 PM
where to find a cnc 4th axis table "servo"?? mik32176 General Metal Working Machines 3 04-20-2005 07:47 AM
