| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
| Well if you're using the Mach3 Wizzards, you enter the tool information in the particular wizzard that you're using. Tool definitions are inputed into the software that you're using to translate your CAD drawings into G-Code (i.e. MeshCAM, CAMBAM, etc.). Mach3 take the G-Code from the tools above and does all the step and direction stuff to make the machine move. Paul |
| Thank you, I have been banging head around today trying to figure out a few things Mach. I haven't had much time with my new alibre cam software. That will come after I have good grasp of Mach3 and how to make sure it is set up right. |
| Mach3 doesn't need to know what type of bit it is. If you use G41/G42 radius offset or G43 length offsets, then you enter the length and diameter in the tool table. Config>Tooltable
| If the program was written as a centerline of cutter and uses a G41 or G42 then it should be nominal 0 then the machine operator can adjust ± from there. If the program was written as edge of cutter and uses a G41 or G42 then the programmer will need to tell you what he/she used. Normally it looks something like (Comp diameter 0.1" up from theoretical sharp point). |
| Tags |
| dremel bits, mach3 |
| Bring your own tools or does your company supply tools? | ZipSnipe | CNCzone Club House | 10 | 02-04-2011 07:06 PM |
| Newbie- Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder | router101 | General CNC (Mill and Lathe) Control Software (NC) | 3 | 11-03-2010 04:46 PM |
| Mini-CNC machine tools and CNC machine tools-ray machine | aiven.xie | Product Announcements & Manufacturer News | 0 | 08-14-2009 09:50 PM |
| how to set tools | cob | Mach Mill | 6 | 07-07-2008 10:05 PM |
| cme-tools.com? | HogDog | General Metalwork Discussion | 2 | 12-09-2004 09:44 PM |
