| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
| Don't know what type of machine, but there is usually a homing sensor, either mechanical/roller or proximity. The sensor must find a cam, piece of metal or other element designed to trigger the sensor during the homing cycle. Your problem could be a bad sensor, a trigger that is bent, loose or missing or a loose or broken wire between the sensor & input module. There may be over stroke cam(s) for the axis too, so make sure you're checking the correct system. If you can get access the the sensor, try starting the homing process and then trigger the switch or sensor to see if the sensor/switch and everything after it is OK. Proximity sensors should typically be adjusted within 1/16". If the homing cam or switch are moved during the repair, be aware that your axis home position (Zero Null Offset or modified home position) will probably have changed and that you'll need to check the alignment. Part programming origins and tool positions may also be effected. It is usually wise to park a rotary axis at the zero position and to pay attention as it homes out if there are any wire/hoses that might be damaged if it goes too far. |
Somewhere in homing /limits untick enable the A axis homing. I used the A limit port bit for an external cycle start switch. I just rotate the 4th axis manually to zero, and hit the screen zero. You put something in the chuck and it is never near zero anyway.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Bell, Try looking under : Ports and Pins -- Input Signals And make sure the A axis Homing is NOT enabled. Hopefully the screen shot will come through.
__________________ Art AKA Country Bubba (Older Than Dirt) |
| How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? | Calico | PCB milling | 11 | 07-12-2011 06:02 AM |
| Need Help!- "Homing Milltronics Partner 4/Centurion 5" | RonRogers | Milltronics | 14 | 06-02-2010 05:00 PM |
| Need Help!- "motor steps per resolution" and "driver microstepping" settings | margni74 | LinuxCNC (formerly EMC2) | 9 | 10-24-2009 02:33 AM |
| "J" head type "millport"(tiwan,1980) clutch | marksbug | Bridgeport and Hardinge Mills | 1 | 08-17-2009 10:48 AM |
| Homing the 4th Rotary Axis "A" | Paraprop | Carken Products (Deskam, DeskCNC etc) | 4 | 04-15-2008 05:01 AM |
