Old 06-15-2010, 07:18 AM
stk2008 is on a distinguished road
Feed hold does it work?
Hi all I need some advice please I use mach 3 to control my home made cnc machine.
I was machining out some letters from aluminum and my phone went so I pressed space to hold feed and when I came back I pressed alt R to restart feed.
but it went mad it went across my work I dont know where it was going as I stopped it but instead of carrying on from where I held feed it went off at an angle across my letter any reason for this?.
Please advise as I would like to use the feed hold feature as it is handy but at the moment it is no good if I have to restart the program again.
Cheers
Old 06-15-2010, 08:06 AM
M250cnc's Avatar
M250cnc is on a distinguished road
It does work but you get different results depending on what version of Mach you are running, as always.
I seem to remember that if you are on a circular move then start will not work, you have to go back to the nearest linear more and set RUN FROM HERE.
The best thing to to try things out like this cutting air so you can be sure of the result before running a part.
HTH
Phil
Old 06-15-2010, 09:33 AM
Ah ok that's a shame I may have been on an arc or some thing and it did not like it.
Cant remember what version im on now but I must upgrade if the new version support this better is this the case?.
Old 06-15-2010, 10:38 AM
ger21's Avatar
I use it occasionally without problems.
Old 06-15-2010, 12:06 PM
Well that is the thing I do remember using it a lot a while ago and never had this problem.
Any one got any ideas could it be some silly setting?.
Work holding options to hold thin round work? .024, .046 etc KyleH2 General Metalwork Discussion 0 06-07-2010 01:22 PM
Need Help!- Feed Hold Problem metx Fanuc 2 01-30-2009 10:10 AM
Feed Hold HelicopterJohn Haas Mills 10 04-24-2008 09:57 PM
Door Feed Hold 1ctoolfool Haas Mills 2 09-12-2006 09:45 AM
What should Feed Hold actually be?? REVCAM_Bob Servo Motors and Drives 4 01-22-2006 12:04 PM
