Results 1 to 7 of 7
Thread: Rapid to 1st point problem
    Dec 2005
    Hey guys, I've been having this problem with Mach3, but I don't know if it's Mach's fault or if my post processor is creating code that Mach doesn't like.
    Ok what's happening is that Mach reads the line, rapids to the point, stops with out deceleration (loses steps), starts spindle, then continues to rapid to the point with no acceleration (losing more steps). I've been editing the code to put the M3 line before the first move, but its a pain when its a big program. Im using the MPFAN post in MasterCamX. Has anyone else had this problem? And do I have to edit the post processor to fix this?
    Shaun
    my x2 conversion ------> http://www.cnczone.com/forums/showthread.php?t=36403
    Mar 2003
    Shelby Twp, MI....USA
    Do you have backlash comp enabled? That's the only thing I can thing of to cause what you're seeing.
    Dec 2005
    nope :/ i have such little backlash that I don't bother.
    Shaun
    Registered M250cnc's Avatar
    Sep 2007
    England
    You may have the motor tuning wrong
    Press the tab key to bring out the MPG and make sure the SLOW JOG RATE is set 100%
    Then try jogging you will find out by jogging if the machine behave the same as in G Code
    Mach3 can only move at the speed you have set in tuning
    Re the PP you should have the Offset line before a move otherwise expect to crash i can't help on editing the PP
    Phil
    Dec 2005
    I can rapid around just fine, no missed steps. And this only happens in lines with an m3 command. I think ill have to edit the post file to fix this, but I've never heard of this happening to anyone else...
    oh yeah my computer is 933mHz, 512mb ram, 32mb vid card, win xp, and no other programs running.
    Shaun
    Mar 2003
    Open task manager while running the g code and see if your CPU usage goes to 100% when you see the problems.
    Dec 2005
    cpu usage goes to 70% when a program is running.
    Shaun
    1. EnRoute Rapid Texture Problem
      By ClassicDoors in forum EnRoute
      Last Post: 02-26-2010, 02:18 AM
    2. Fagor 8025 Rapid problem
      By Todd H in forum Fagor Automation
      Last Post: 12-08-2009, 02:45 PM
    3. Need Help!- No rapid 'problem'
      By Tom Curran in forum CamSoft Products
      Last Post: 11-24-2009, 07:45 AM
    4. MDI rapid vs jog problem
      By Chris64 in forum Mach Software (ArtSoft software)
      Last Post: 03-08-2008, 10:34 AM
    5. 2.5D pocketing rapid problem
      By mayhugh1 in forum SprutCAM
      Last Post: 11-02-2006, 02:58 AM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
