| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
hi i use plasma table (with sheetcam & THC) my question : i use rapid clearance in sheetcam for safety and refrence before each Part cut i run code ,why after pressing "feed hold" and then "reverse", Z axis goes allways at "rapid clearance". how to correct this ? please see my code |
Best way to do feed hold with no strange moves is to put lots of M1's in the code, then hit M1 on screen. Cycle start to continue. I use it all the time because feed hold MUST do strange things, because the instructions to move the machine have already been posted in the queue, and the upper level program might not stop it correctly. This is quite noticeable if using feed hold on circular interpolation. Just use lots of M1s and it will always pause at the next M1 if enabled on the screen-1 M1 key. You could even program an external switch to do this.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| thx neilw20 i think that use feed hold is risk, possible lose step. but i dont use M1 ,because I am unaware of its occurrence,If during the cutting triggered problem, I use it. Back to issue: please test it code in your pc .you will see when press feed hold and then reverse run, Z goto rapid clearance that we adjust in sheetcam. what ??? |
Can't run your code, because my machine is setup for a big job, and my wife would kill me if it stopped working. It looked OK in my NCPLot program, but that has no reverse feature. I have never used reverse with a milling cutter. Might try it one day!
| i think this problem is new for anyone. mach forum |
| Goto (0,0,0) in Mach3 | rbocaz | Mach Plasma / Laser | 3 | 11-05-2009 07:08 AM |
| Need Help!- (GOTO) function | traxxtito | Fanuc | 11 | 07-02-2009 06:56 AM |
| GOTO Z button | TMaster | Mach Mill | 10 | 05-30-2009 07:18 AM |
| Z goto 0 first ? | SScnc | Mach Mill | 7 | 08-10-2008 12:31 PM |
| Need Help!- GOTO Z | monte55 | Mach Software (ArtSoft software) | 12 | 02-06-2008 09:03 AM |
