Old 05-10-2010, 07:42 PM
router101 is on a distinguished road
toggle axis 4 dro to a-b-c
Gooday
Im trying to run reprap gcode to extrude parts.
The two steps in this are using E for extrude and F which is a temperature setting.
I have been able to assign the E for extrude axis in the G code to C axis using search and replace text editing.
I want to be able to toggle the 4 dro in program1 and mdi screens between A, B, C, axises.
While I can see all six axises in the diagnostics screen.
Thanks Peter.
Old 05-10-2010, 08:09 PM
ger21's Avatar
I'm pretty sure you can't toggle the DRO display, but you can use the Swap axis command, which will basically use a different axis then the programmed one.
Old 05-10-2010, 08:47 PM
Thanks, that would work if I only needed to see four axises.
I plan to use five or six axises, and would like to toggle the fourth axis dro to check important movement as required.
need help with HAL - toggle settings with one button DrStein99 LinuxCNC (formerly EMC2) 2 10-22-2009 08:46 AM
Jog Mode Toggle dynamotive Mach Software (ArtSoft software) 0 09-29-2009 09:04 PM
Robotool CVM1 toggle switches fred.rowe Want To Buy...Need help! 0 07-25-2009 11:05 AM
Q: Mach3 Wiring / Toggle Switch Deviant Gecko Drives 3 02-10-2009 09:21 PM
DIY Toggle Clamp Holddowns Regnar DIY-CNC Router Table Machines 6 04-19-2007 07:33 PM
