| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I have a CNC router for woodworking with the computer screen at the end of the router table instead of at the side. The display for the toolpath in Mach 3 is oriented in the other direction which is very confusing when I'm trying to figure out where its going to cut. Does anyone have a way to change this or it there a plugin for mach 3 that can fix this? |
| You can't change the orientation of the display. Is it just rotated 90° from your machine, or reversed? If it's reversed, most likely your machine is running reversed.
I am experiencing the exact same thing. Y+ axis points north (up) on the toolpath display. On my setup x home is bottom left and Y limit is upper right. The toolpath is completely opposite. Doesn't affect the outcome but is a little disorienting. |
| Problem- Toolpath display. | RobH | Mach Mill | 3 | 03-31-2010 10:57 AM |
| Problem- Toolpath Display | summy | SolidCam | 5 | 12-01-2009 07:51 PM |
| CRT/Display, '91 VF1 | TheArmoury | Haas Mills | 0 | 11-04-2009 10:57 AM |
| RPM display | fatal-exception | Mach Mill | 0 | 11-24-2007 03:02 PM |
| Toolpath display | raytor | Mach Mill | 1 | 11-04-2006 08:54 AM |
