| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I have the demo version of Mach3, Version R3.042.040. I use LazyCam to open a DXF, and then i set the cut depths and hit the clean button, and then hit the "post Gcode" button. It then saves the file, and when i open the tap file in either notepad or Mach3, it only shows up with 49 lines of G code (which is barely enough to cut out the number "7." What is causing this issue? EDIT: sorry i found that the issue is that LazyCam has to be licensed. Is there a free version that can open a dxf, set the cut depths, and export a tap file? |
| Actually, if Mach3 is licensed, then the 50 line LazyCAM limit disappears. Buying a LazyCAM license unlocks other features in LazyCAM
| What software is good for GCODE generating | civoki | General Metal Working Machines | 4 | 08-11-2009 12:57 PM |
| Bridgeport Boss gcode loss of lines | dougputt | G-Code Programing | 0 | 09-03-2007 09:41 PM |
| Generating paths (Gcode) from Illustrator CS2 | bigal | General CAM Discussion | 1 | 06-14-2007 04:05 PM |
| looking for Machining (GCode generating) service | sa6200 | Employment Opportunity | 8 | 05-28-2007 01:27 PM |
| Radius problems when generating gcode from bobcad for mach3... ? | scyan | BobCad-Cam | 7 | 12-14-2006 12:33 PM |
