| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I didn't want to continue to hijack the pendant thread, so I though I would start a new one for this. I uninstalled my older mach2 version, and installed a newer version. Got everything working except for spindle control. I have tried everything I can think of. Can anyone share how they got their spindle on/off working in the newer versions of mach2? (I have read the manual and no luck at all) I had this working before, man, I miss working in a shop where there was a guy you called when the computer wasn't working right! co |
| Did you go to Configure>Ports and Pins and setup the relay activation signals under Output Signals (Use output 1,2, or 3, and have no more than 3 checked), AND setup the pins under output pins? Then, go to COnfigure>Output Devices, and make sure you uncheck the not used box, and set the spindle to the output you picked previously. That should do it.
| Are you using 6.11M? You might even want to try Mach3. I've heard it's very stable, and has a lot more features.
| All set-up is correct. Spindle toggles on and off on screen, pin address is right, output 1 = CW spindle, Output 1 checked. I am stumped. And now my joystick doesn't work anymore! Sheesh colin p.s. Just checked that the spindle does indeed work when plugged into an outlet directly. |
| CNC Controlled Spindle motor speed control | gregmary | General Electronics Discussion | 13 | 02-27-2009 07:01 PM |
| Spindle motor control for homebrew cncmill | stuart76 | General Electronics Discussion | 2 | 05-21-2005 09:10 AM |
| How to set a relay for a spindle motor ON/OFF control | TTaki | TurboCNC | 2 | 03-09-2005 06:26 AM |
| Can Mach2 control my phase inverter | MrBean | Mach Software (ArtSoft software) | 3 | 10-12-2004 07:20 PM |
| Tutorial for Spindle Control | teilhardo | Xylotex | 29 | 06-22-2004 10:43 PM |
