| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
| Hi friends, We are a CNC dealer from India. We have bought a "KX-3" model milling machine "SP2215" made by "SUMORE", china. It runs with MACH-3 controller software. X,Y and Z axis motors and drives are facing no troubles. Machine tool head spindle motor runs only when not in PWM mode ( Pulse Width Modulation). It could just be made ON and OFF. Speed control using PWM mode is not working. Please help me fix this issue. "MBLC-1100-300H" drive made by HONCAR is driving that spindle motor. I need the end connection details of the drive to run in externally without the controller MACH-3 to check it. HONCAR is not responding me regarding this issue. Also i doubt that the trouble may be with the controller MACH-3. Somebody help me with tha parameters to be set in MACH-3 to run PWM mode succesfully. Regards, Guru krupa electronik services, Chennai, India. |
| Does the spindle drive accept PWM directly? If not you need a PWM to analogue or whatever type of contol the drive has, converter. If the drive manuf. are not responding, did you try the MTB? As a last resort you may have to check that Mach is outputting a PWM signal and reverse engineer the type of control the Sp drive has. The Mach site itself should also supply a lot of info in the tutorials. Al.
| spindle motor and spindle control dont work | customcncparts | Milltronics | 0 | 10-01-2009 02:08 PM |
| Need Help!- VFD to control CNC Spindle Motor | kudos | Phase Converters and VFD | 3 | 07-30-2009 06:00 PM |
| Newbie- Need help for Sx3 conversion (spindle motor control) ! | ben2toul | General Electronics Discussion | 0 | 04-30-2009 12:09 PM |
| Spindle Motor Speed Control | JHCHOPPERS | Bridgeport and Hardinge Mills | 7 | 03-08-2009 09:39 PM |
| Spindle motor overload, DX 32 control | Gncc50 | Bridgeport and Hardinge Mills | 2 | 11-15-2005 12:49 AM |
