Old 03-20-2010, 11:27 AM
Woodenspoke is on a distinguished road
Image to mach3 gcode
I have some simple 2D items I would like to convert from a vector or raster image directly to Mach3 capable gcode.
That is without having to redraw the shape in a higher end program save it as dxf or dwg and convert it in a cam program. Any ideas would be appreciated.
I am using a mini mill and the items are shell inlays for guitars
Old 03-20-2010, 12:13 PM
ger21's Avatar
Converting from Raster and Vector are two very different things, that require very different methods. Raster is not a good choice for an inlay pocket, and should be converted to vector first.
Vectric's Cut2D will do the pocketing, is easy to use, and not too expensive.
Conditional gcode execution in Mach3 bobeson Tormach PCNC 5 12-13-2009 08:39 PM
Grayscale image to gcode gourky OpenSource Software 0 10-31-2009 04:53 PM
Image (Greyscale) to GCODE rackbox OpenSource Software 19 01-27-2009 04:06 AM
Image to Vector And or GCode whoafat General CAM Discussion 0 01-28-2008 09:44 PM
Mach3 image conversion trouble obscurity Mach Software (ArtSoft software) 7 09-08-2006 05:22 PM
