Old 04-27-2005, 12:19 AM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
Mach2 G02, G03 Modal?
I have just started to familiarize myself with mach2.
I loaded a simple lathe program and tried to cycle thru it. In the display there are lots of lines, why? and when the program runs all moves after a g02, g03 are circular ?? only feed moves are supposed to be circular, not the rapids! what gives is there a switch I am missing?
sorry I was incrementing the program too fast.
what the real problem is. is the IJK comands aren't machinging correctly. I change the IJK in the config from incremental to absolut and back and it makes a change but it is still wrong. I use the HAAS post for a standard fanuc style g code.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 04-27-2005, 12:47 AM
miljnor's Avatar
S.N.A.F.U.
i have found the problem. The go2 g03 codes are backward in mach2 is there anyway to change this in Mach2 I would like them to be standard to a commercialy available post. and not have to pay for a new post that does it backward.
thanks
Michael T.
Old 04-27-2005, 05:35 AM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
Hello,
I have found this problem as well with Mach2/3 Lathe, the work around is in your CAM post, (I use OneCNC), set your "Arc interpretation" to approximate by lines and set your tolarance as low as your controller/machine will go, I use 0.0001 you will find although this adds lines of code, it quits those strange "Crop Circles" in the tool path.
Scott
Old 04-27-2005, 10:06 PM
miljnor's Avatar
S.N.A.F.U.
I know i can get the post for gibbs modified. I was just wonding if Art at artsoft was emulating a g-code interpreter when he decided to make the graphics like a normal manual lathe instead of the CNC lathes (which is typicaly upside down).
When the graphics are inverted the G02 and G03 are rendering in the appropriate direction.
I think Mach2 is decidedly one of the best computer based controlers on the market, but I wish all of them had a little more interoperability.
thanks
Michael T.
Wierd NC Code and G-Code Tazzer General CAM Discussion 10 01-09-2012 01:07 PM
using vmc as a lathe ddwinn General CNC (Mill and Lathe) Control Software (NC) 7 04-25-2005 07:48 AM
Engraving Macro MachineSMM General CNC (Mill and Lathe) Control Software (NC) 12 03-03-2005 05:32 AM
Conic sections with G02 & G03? JimmyJazz G-Code Programing 4 02-16-2005 04:44 PM
why G17 G18 G19? T-bolt General CAM Discussion 14 11-28-2003 10:01 PM
