Old 04-24-2005, 08:19 PM
jdholbrook is on a distinguished road
Newbie question on axis orientation
Just got my Taig/xylotex package up and running and am a bit confused as to which way the axises (?) need to go.
Which way does -X go? left or right? Do I home on the left end of the table or the right? What about the Y axis?
Looking thru some G-code I see negitive numbers. Will that mean I need to zero on the middle of the table?
Also.
How do I work the backlash? I've set it to 0.004" and turned it on in Mach2 but when I draw a circle with a pen clamped to the head the ends don't exactly meet. They miss by a small amount.
I've read the manual and have it open as I've worked with the unit. Still a little confused on the backlash tho.
James
Old 04-24-2005, 09:14 PM
Al_The_Man's Avatar
On a Mill the axis coordinate system is a bit confusing at first as the axis direction is defined as spindle movement, but usually the spindle does not move in the x,y only z.
Facing the front of the Mill, Z is -down + is up. X- the table has to move to the right, table move left for X+.
Table moves forward for Y+, to the rear for Y-.
MasterCam 4th axis project question HomeCNC Mastercam 19 12-12-2005 06:17 PM
4 axis control board question cnctoolman Hobbycnc (Products) 1 04-01-2005 03:30 PM
simple newbie question swarfmacdaddy G-Code Programing 4 01-30-2005 06:37 PM
z axis direction question. ljoe1969 TurboCNC 3 05-21-2004 08:53 PM
Z Axis Height question? redbaron DIY-CNC Router Table Machines 4 02-06-2004 08:34 AM
