I asked the following question on the sheetcam forum under cnczone but got no replies so I figured I would ask here... Is it possible to have sheetcam, using the plasma cutting tool, just pierce the center of the circle without cutting out the the circle itself? Or just pierce the center of drill cross marking? |
| Well... I can get it to work in sheetcam viewing it as a simulation but when I load it in Mach3, the holes designated as a drill function in sheetcam disappear and all I see is the outline to be cut with plasma. Does anyone know what I have to do in Mach3 to get it to work? Any suggestions welcomed. I have supplied the link to the file I'm using to test this below: http://www.needfulthings.net/files/P...DRILL_TEST.job TIA |
| Have you tried to drill out a hole after it has been pierced by a plasma torch? If you are trying to make a small hole, slightly larger than the pierced hole I am pretty sure you will break every drill bit you try. I have tried to do this with 1/2" hole with minimal success. Good Luck. |
I always use Titanium Nitride Coated High Speed Steel Step Drills and never had an issue. |
| Would really appreciate the info... |
#11
| When I am drawing and I want a pierce to drill out, I make it a perfect circle between .2 and .5 diameter. When I bring it into sheetcam I make sure the use points for drilling is checked on the drawing options popup box. In sheetcam I select the circles ( they should have a plus mark in the center.) I move them to a new layer. Or you could have them in their own layer in the dxf file. I choose the drill function in the operations tab. choose the layer with the circles. Choose the plasma tool needed for your thickness. Make sure the min hole size is smaller than your circle size and the max hole size is larger than your circle size. When sheetcam shows the green cut lines you should have a tiny green waggon wheel looking thing in the very center of your circle. That is what I do. |
#12
| Thanks lowpull! You are the man! Reading your explanation helped determine what I was doing wrong. When selecting the drill funcion, I was using tool:2 - the drill instead of selecting tool:1 - plasma. Thanks again for setting the record straight on how its done. |
| piercing heavy plate | awjareme | CNC Plasma and Waterjet Machines | 14 | 01-18-2011 11:54 AM |
| Piercing holes | tulsaturbo | SheetCam | 6 | 04-28-2010 12:22 AM |
| ? how to tap holes? | eloid | DIY-CNC Router Table Machines | 5 | 09-01-2009 07:39 PM |
| Excessive piercing problem | Ironworks | PlasmaCam | 12 | 04-30-2009 06:43 AM |
| electronics boards piercing machine | shreifali | Industrial Hobbies (Support forum) | 11 | 02-19-2007 05:23 PM |
