| You get sharp corners from torque (which begets acceleration). You have servos and high ratio gear reduction so you should be able to crank your torque up in motor tuning. If you still continue to have bad corners then you may have some backlash in the system. Whatever your backlash is in the gear box is multiplied by the pinion gear setup ratio. If you are cutting thin material use the smallest tip and current setting combo (by the charts) that you can so you can cut at slower speeds. It's easier (quicker) to accelerate from 0 to 120 IPM versus 0 to 333 IPM. Your acceleraion and deceleration in motor tuning determines a lot as to how far away from the actual toolpath your cutter will deviate. The software tries not the make moves that violate the settings and could cause a servo fault. The amount of mass you have to move with a given torque predicts the acceleration curves. If you have a big heavy gantry then you need lots of torque to make it stop instantly and accelerate in another direction. I don't know what size gantry (weight you have to move) or the servo motor torque ratings or if it's dual drive (two motors). All those things effect the perfomance of your table and predict the acceleration you can acheive and ultimately the tightness of your turns. TOM Caudle www.CandCNC.com |
| I think mach starts rounding corners more the faster you go. It has to to keep up its feed rate or banging would occur. Exact stop mode gives square corvers but can't run that on a plasma . There are settings to reduce rounding, but i'm not sure where.
__________________ Manufacturer of CNC routers and Viper Servo Drives www.LarkenCNC.com and www.Viperservo.com |
| I have to agree with Tom.....use a smaller nozzle orifice and cut at a slower speed. If you are using a Hypertherm Powermax unit....the FineCut consumables are designed for slower speeds, lower power and more intricate cutting. I would suggest getting your speed to a maximum of 120 IPM....make sure your torch to work distance is correct (too high will also round corners). Jim Colt "I am plasma cutting 330 in/min, as you can see the letters have square edges but they are cutting round, is there a cv setting wrong, or if anyone can tell me what to do or set differently I would appreciate it Thanks" |
| I think he's talking about the actual motion This is from the Mach3 CV settings PDF file http://www.machsupport.com/docs/Mach3_CVSettings_v2.pdf
| Plasma cutting AL | BarnBurner | CNC Plasma and Waterjet Machines | 5 | 04-17-2008 07:58 PM |
| Plasma cutting | jimini | Employment Opportunity | 2 | 03-05-2008 10:28 PM |
| Looking for some Plasma Cutting | ArcadEd | Employment Opportunity | 4 | 05-09-2006 09:26 AM |
| Plasma cutting mdf. | ynneb | CNC Plasma and Waterjet Machines | 8 | 11-05-2004 08:56 PM |
| plasma cutting? anyone using it? | rmacguiver | CNC Plasma and Waterjet Machines | 11 | 11-05-2004 09:31 AM |
