I am new to this whole process so please excuse my ignorance, I’m using Inventor 2010 Pro to design my parts, SheetCAM for the g code, and Mach3 for the controller software. I can design the parts fine and convert them into g code using sheetCAM but when I load the g code file into Mach 3 I keep getting a error message (unknown g code used/line 11) the code in line 11 is G23. What can I do to keep sheetCAM from posting this into my code? |
| Quite often, CADCAM post writers follow a series of steps to enable a machine to work effectively Many posts are written in a generic fashion, to suit many controls, but 9 times out of 10, modifications are needed to suit your control Try to analyse what was intended to be controlled by the G23 and then see if your control has the same function, but as a different G-code. There may be comments in the "post" that may assist For example, Fanuc G43 on a CNC mill is tool length compensation but on an Okuma it is G56, this discrepancy shows it should be replaced not deleted, so caution is needed. If your machine does have an alternative G-code, it should be a simple edit to substitute the code with the correct one in the "post processor" file |
TOM Caudle www.CandCNC.com |
| Need Help!- UNKNOWN FAULT CODE | CNC_BOB | OKK | 5 | 05-18-2011 08:09 PM |
| ps 101 error code help! | AC_Engineering | Bridgeport and Hardinge Mills | 2 | 11-13-2007 07:01 AM |
| Error code in SprutCAM? | MichaelHenry | SprutCAM | 4 | 06-25-2007 08:24 AM |
| art code error | Mike Boarman | Mach Software (ArtSoft software) | 4 | 12-30-2006 11:46 PM |
| M01 error code | MRU | Mazak, Mitsubishi, Mazatrol | 2 | 06-12-2006 08:59 AM |
