Results 1 to 4 of 4
Thread: Use Hypertherm 1000 arc ok without THC
    Nov 2008
    I am assuming it is possible to use the hypertherm 1000s arc ok or machine xfer dry contact signal to tell the soundlogic board, and then mach to start machine motion after arc is made, but how would that be done?
    Torchead or anyone else got any ideas?
    Brian =)
    Jul 2008
    Use pin 12 and 14 from the back of the Hypertherm to turn on THC On input in the pin config table.
    Nov 2008
    That easy? Wow, no wonder I couldnt figure it out!! LOL I thought that was something to actually turn on the THC or similar, not for arc ok. I will try it out tonight.
    Jul 2008
    Almost forgot!
    I failed to mention that you need to turn the THC box on in the run screen so it doesn't move until the Hypertherm says the arc has transferred. I made that omission when I first set it up.
  1. Hypertherm Powermax 1000 and Dyna4000 controller?
    By mgmetalworks in forum DynaCNC
    Last Post: 03-13-2013, 10:39 AM
  2. 3/16" AL with Hypertherm Powermax 1000
    By zeoncomp in forum General Waterjet
    Last Post: 01-16-2008, 01:18 PM
  3. cutmaster 81 vs hypertherm 1000
    By dgalaxy in forum General Waterjet
    Last Post: 05-19-2006, 09:11 AM
  4. Hypertherm 1000 Machine Torch Help
    By mattmu in forum Plasma, EDM and other similar machine Project Log
    Last Post: 12-21-2005, 02:12 AM
  5. THC 300 and hypertherm 1000
    By Don C in forum General Waterjet
    Last Post: 10-30-2005, 06:33 PM
