Results 1 to 2 of 2
Thread: Manual Control of z axis with progam running
    Aug 2008
    Hi, Could anyone tell me if I can manually run the z axis at the same time the mach 3 is running a program. Is this possible?
    Jul 2005
    Yes. You need to setup an UP and Down switch (hopefully isolated) into the THC UP and THC DOWN inputs in MACH (Config/ports & pins/Input Signals) Then you need to go into Mill Options and turn on the "Allow THC operations even when not under THC control" checkbox.
    On all of our MACH based THC interface our I/O breakout cards have isolated inputs for an external UP and DOWN manual control (mostly used for oxy-Fuel cutting). The signals are in parallel with the UP and DOWN signals from our DTHC so you don't have to swap over a bunch of signals for doing plasma or manual cutting.
    TOM CAUDLE
    www.CandCNC.com
  1. I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control
    By vettespeed in forum Bridgeport and Hardinge Mills
    Last Post: 05-30-2012, 09:21 PM
  2. Problem- Control Running Slow
    By dpellarin in forum Fadal
    Last Post: 07-21-2008, 09:31 PM
  3. Software for single axis manual control?
    By Corruptor in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 02-07-2008, 10:39 PM
  4. Move your steppers. Free XP progam. Simple
    By zippys in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 05-21-2007, 07:32 AM
  5. help me find a nc backplot progam
    By billy-bob-bo in forum General CAM Discussion
    Last Post: 03-09-2007, 07:43 PM
