Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 09-01-2008, 02:54 PM
marcmnrsports is on a distinguished road
ez router / thc help
marcmnrsports
torch height help
hi all
i am really desparate for some help here
i have an ez router setup, running scribing / engraving, plasma cutting / router
i have the thc 300 unit and cant seem to get it to work arc start , arc ok both light up anbd work, but torch up down / floating head system does not, when i do cut something the torch gradually creeps down untill it scrapes along the surface, can i disble the height adjustment and just run manually untill i get more parts from ez router to fix my th problems
many thanks
marc
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 08:51 AM
Newbie- Does anyone own a EZ Router Machine? Plasma or Router. sngatlanta Commercial CNC Wood Routers 30 04-11-2008 11:48 AM
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 11:33 AM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 04:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 01:27 PM
