Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 07-07-2008, 06:24 AM
jashoury is on a distinguished road
Question Amada laser acrylic
I have Amada Pulsar LC2415 3k i need urgent help in cutting acrylic/Lexan , every time the head touches the material "Alarm massage over travel Z axis" what should I do, I used cutting condition with clean air cut, used different value for Nozzle gap still same problem, thankx
Old 07-07-2008, 10:25 PM
wilsonrog is on a distinguished road
amada
you have to set the nozzel gap by hand then turn off the trace.you must be very very careful when the trace is off bad things can happen fast.
Old 10-10-2008, 08:13 PM
M Ferreira is on a distinguished road
also you can set the tickenes material in the cuting conditdion, it is safe the set only the nozzel gap, to be more safe you change the parameter (in cut condition) "Z start folow" to a big value, when the cuting head get the position (thik material + nozzel gap+ Z start folow) the z axis will decelerate. dont forget to turn of the Z sensor at control panel.
never use oxigem to cut acrilic or other organic material, very easy to "burn" your machine!
be careful with the toxic gas! have a goo look!
sorry to my bad english
Tags
acrylic, amada
amada laser 55belairtim Want To Buy...Need help! 1 03-23-2009 04:19 AM
amada lasmac edgegauthier Fanuc 0 02-11-2008 12:52 PM
Amada Fanuc 0L problem laser rick_7037 Fanuc 7 12-16-2006 03:48 PM
laser cutting acrylic - art application charper Laser Engraving & Cutting Machines 2 11-07-2006 01:50 AM
CNC Amada Apelio G-Codes pwright238 G-Code Programing 2 10-16-2006 04:05 AM
