Change your IJ mode in general config.
1. I'm using the demo ver. of sheetcam and Mack3
2. Drawings are made in CorelDraw
3. Have use stock dfx files to test
Here is the problem....When I generate the machine code and open in Mach 3, in the background there are circles? Now, I have no layering in sheetcam that I'm aware of. Also, by importing dfx files that others have drawn, I have eliminated it being a Corel Draw problem. The circles are not seen in sheetcam only the drawing...In this case the letter F which, is what make this so confusing.
If you have not guessed it yet, I'm new to this trying to accelerate the learning curve before my Plasma table is built.
I will include the code to a simple F and maybe you can see the problem?
The more I use the demo, the more circles show up???
Thanks,
Mick
N0000 (Filename: f.tap)
N0010 (Post processor: Mach2 plasma.post)
N0020 (Date: 2/11/2008)
N0030 G20 (Units: Inches)
N0040 G53 G90 G40
N0050 F1
N0060 S500
N0070 (Part: f)
N0080 (Process: Plasma, Layer 1, 1/8 steel)
N0090 M06 T1 F41 (1/8 steel)
N0100 G00 Z0.5000
N0110 X0.4624 Y3.8882
N0120 Z0.2000
N0130 M03
N0140 G04 P1
N0150 G01 Z0.1000 F10
N0160 G02 X0.5584 Y3.7922 I0.0000 J-0.0960 F41.0
N0170 G01 Y0.0619
N0180 G03 X0.5884 Y0.0319 I0.0300 J0.0000
N0190 G01 X1.0826
N0200 G03 X1.1126 Y0.0619 I0.0000 J0.0300
N0210 G01 Y1.7264
N0220 X2.8326
N0230 G03 X2.8626 Y1.7564 I0.0000 J0.0300
N0240 G01 Y2.1968
N0250 G03 X2.8326 Y2.2268 I-0.0300 J0.0000
N0260 G01 X1.1126
N0270 Y3.3219
N0280 X3.1054
N0290 G03 X3.1354 Y3.3519 I0.0000 J0.0300
N0300 G01 Y3.7922
N0310 G03 X3.1054 Y3.8222 I-0.0300 J0.0000
N0320 G01 X0.5884
N0330 G03 X0.5584 Y3.7922 I0.0000 J-0.0300
N0340 G02 X0.4624 Y3.6962 I-0.0960 J0.0000
N0350 M05
N0360 G04 P0.3
N0370 G00 Z0.5000
N0380 M05 M30
Your the man!!!!!!!!
Thanks, I was getting a little frustrated, now I can practice and will purchase the full versions of Mach3 and Sheetcam.
Thank you very much,
Mick
