I have had my Homebuilt Plasma up and running now for a few weeks and I am using Mach3 ![]() I would like to know what is the best method to draw DXF files for the smoothest movement of the machine. I know that the CV Settings can affect the smoothness. At present I have a part that has about 6 Arcs joined end to end in a tightening radius. When I Plasma this, I can see the machine visibly pause for a split second when it encounters the next Arc start. So which are best Arcs, Circles or Polygons? Thanks Andy |
I assume you mean polylines. At my last job I designed parts to be laser cut. In order to get continuouse smooth tool path we had to polyline(I assume thats what you mean) the tool path. The geometry was made up of arcs, lines etc but when polylined it is viewed as on continuous entity. If we failed to polyline it would do as you said or worse. It looked at each entity as small subpaths so ti might cut an arc in one place and then shoot 3 feet away and cut a different segment and basically keep skipping around. The whole part would cut but extremely inefficiently and with poor quality as it woule leave a mark on th pierce and exit of eac cut. Consider endpoint bieng coincident and these marks amplify. Another good thing to to is create your own lead ins and outs in your geometry and not leave it up to the software. For instance if I were to make a 4" x 4" square I would make one corner my desigmnated lead in lead out and extend the edges there so that my pierce and lead out was off the desired finished geometry. (see pic) I have never used a plasma but I assume some of the things I mentioned are common to all tool path generation |
| I don't think it really matters. In Mach3, if you have CV turned off, it will pause at each line of g-code. With CV turned on, it shouldn't pause at all. One important thing is that all the CV settings should be turned off, both in the general config page and the settings screen. If any of the CV settings are turned on, you'll get mixed results. How your CAM program interprets your drawing and creates the code is the only thing that the way you draw the part will affect. Imo, there only one way to draw a part in a 2D CAM program. A circle is a circle, an arc is an arc, a line is a line. You can't substitute one for another and end up with the same drawing. You either draw your part correctly, or you don't. Bottom line is what's in your g-code, not what's in the drawing.
The software would just ignore polylines! we had to convert everything to arcs, lines or circles etc ![]()
Doe'snt Mach3 when using CV have a 'look ahead' feature, I don't know what works best with tis feature? I think if it was drawn as a Polyline hopefully it will cut in one smooth continuous movement. I need to do some tests to see what works best..... Thanks Andy |
| Hi Gerry Thanks for the input ![]() I will have a look into the CV settings, I see a lot of people struggle with CV (myself included!) I was told to turn off CV Feedrate, and I did this for a while. But I was getting a very wavy line coming out of a sharp corner. On testing my machine I could visibly see the axis 'juddering' as it was accelerating out of a sharp corner. So I turned CV Feedrate back on, and the juddering disappeared! But I am still not 100% happy with the cut quality, on some parts it is superb, and on other parts it is not so good.... I will try your suggestions, you say that I should have CV mode turned on but all the settings turned off. In the Config screen under CV Control I should have the 4 items unchecked? Also in the Program Run screen I should have CV Feedrate turned off? Thanks Andy |
| These terms seem to get confused fairly often. "CV Mode" on and "CV Feedrate" off There is a check box for "Plasma Mode" I don't know what it does. Gerry is right, info on these settings is hard to find. Greg |
The Plasma Screenset that I use has a button for CV Feedrate on both screens, and they both do the same thing ![]() Like I said earlier at the moment I have CV Mode on, and CV Feedrate off and then another couple of items are still checked under CV Config. The machine definitely ran smoother with the CV Feedrate turned off. I will try the suggestion of having CV mode on, and everything else turned off. Not tried that configuration yet!.......fingers crossed ![]() Thanks Andy |
#10
![]() Greg |
| True Polygon CNC Turning Offered | npkaye | Product Announcements & Manufacturer News | 0 | 09-30-2007 04:11 PM |
| 3d arcs? | stevespo | BobCad-Cam | 10 | 08-31-2007 09:02 PM |
| turn polygon help | CNCRim | Fanuc | 1 | 09-07-2006 08:18 PM |
| laser show software / polygon imaging | DrStein99 | Laser Engraving & Cutting Machines | 0 | 02-09-2006 01:12 PM |
| Importing polygon mesh (.dxf) into BobCad | rherman | BobCad-Cam | 0 | 06-10-2005 03:08 PM |
