Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 11-29-2007, 05:02 PM
johnt is on a distinguished road
mach3 plasma restart mid-job?
Is there any way,easy or otherwise, to restart a plasma job mid stream?
Say after computer crash or tripped circuit breaker....whatever???
Old 11-29-2007, 08:28 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Can't you referance the machine (X=0.0, Y=0.0) then start the same program with the plasma off, turn the plasma back on just before the spot the machine stopped/ faulted out.
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 12-03-2007, 11:59 PM
2fst4u is on a distinguished road
Easiest way to restart is to move down your code to where the cut stopped. Press the "Run From Here" button. Follow the prompts. You will get a pop up box. In it you should leave everything as is but make sure that the start spindle is not checked other wise your torch will fire as soon as you hit ok. Just remember to start the code where the torch fires and you should be ok. Hope this makes sense. It took me a few tries to get it figured out.
MACH3 PLASMA IN EDIT MODE john robin Mach Plasma / Laser 2 11-28-2007 12:05 PM
Mach3 Plasma G41 G42 CARLES Mach Plasma / Laser 4 07-25-2007 06:08 PM
constant velocity and power settings in mach3 plasma cutting Knut CNC Plasma and Waterjet Machines 4 09-27-2006 11:19 PM
ArtCAM & Mach3 for Plasma and Oxy sunmix Mach Software (ArtSoft software) 0 05-31-2006 02:01 PM
Mach3 Plasma anthony Mach Plasma / Laser 1 05-18-2005 07:21 PM
