#14
| Duh! Why not replace the power control pot on my laser with something like the MAX5450 digital pot. This type of pot uses an UP/DOWN pin (We know this as direction), and an Increment pin (We know this as step). Wire the step and direction as the Z-axis and we have instant digital power control of the laser without needing a mechanical "stepper to pot" interface. ![]() This particular digital pot only has 256 bits of control, but the same theory would be easy to do with a 10-12 bit DAC and a Pic microcontroller taking step and direction inputs to control the DAC. |
#15
| So the bigger general question still exists. Am I wasting my time? Sure, I now know I can make laser power change depending on the requested Z depth, but is this a reasonable or desirable feature? After all, when engraving wood black is black. It wouldn't matter if it is 1/16" deep or 1/8" deep. I haven't really done much with this device other than a couple test engravings on wood and the mod to Mach 3 for paper cutting. |
#16
| Hi, Have you already found (and tested) a decent solution to engrave with a laser using mach3? I'm asking this because I want to replace the stepper drivers from my Chinese HX40A laser with step and direction boards. I know cutting will be no problem with mach3 but engraving I'm not sure |
#17
| I have not engraved yet. I haven't touched my machine since mid June. No time. I did find that I could attach the laser on-off control to the Z axis. This worked well for turning on and off, but as you would imagine, you get a deeper burn during a circular cut than you get during a straight X or Y motion. It's all a matter of speed over the project. I think the BMPtoCNC program I have will do just fine with straight black & white images with no "grey" depth. It produces a nice raster file for Mach3 to run. |
| Rabbit 3040 laser cutter with Mach3 ?????? | Mrebeiro70 | Laser Engraving & Cutting Machines | 5 | 05-17-2009 09:38 PM |
| Running Mach3 for laser cutting questions | CNCadmin | Mach Plasma / Laser | 9 | 09-14-2007 10:34 PM |
| MACH3 Licensing question | turbostang | Mach Mill | 3 | 05-03-2007 09:15 AM |
| Mach3 question | cosmynnec | Mach Software (ArtSoft software) | 0 | 05-01-2006 01:46 PM |
| DeskCNC to Mach3 Question | WarrenW | Carken Products (Deskam, DeskCNC etc) | 4 | 12-31-2005 11:29 AM |
