Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 10-04-2007, 09:49 AM
ADucci is on a distinguished road
Drawing Size and Cut Size Differ - Plasma
I Draw a DXF square 100mm x 100mm in my design software, then import the DXF into Lazycam, the scale on the top right (in lazycam) says 2,23units, however when i click on the layer, the layer information displays the 100mm X 100mm, then i import to Mach3, and the cut is tiny... i cant seem to get my machine to cut the correct size,
i have run the "set Steps Per" function and that moves 100mm when i tell it to... so it seems correct on that side..
I just cant fix this!, any comments.. please
Drawing Size and Cut Size Differ - Plasma ADucci LinuxCNC (formerly EMC2) 5 10-05-2007 05:52 AM
Next size up? BeerFizz Mini Lathe 9 04-09-2007 11:03 PM
X3 base size or minium bench size kenrc Benchtop Machines 2 02-04-2007 07:50 AM
Ballscrew size -vs- project size Alan T. CNC Machining Centers 4 10-18-2004 09:53 PM
What size steppers? cnczoner General Metal Working Machines 6 05-19-2004 12:32 AM
