Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 07-16-2007, 01:20 PM
CARLES is on a distinguished road
Mach3 Plasma G41 G42
WHEN I WANT TO USE the COMPENSATION OF RADIO G41 G42 I WRITE G41 P1 Or G42 P1, BUT the CUT LAYOUT IS NOT CORRECT, MAKES FORMS THAT DO NOT FOLLOW the PROFILE OF the PIECE OR CUTS IN DIAGONAL, IS SOME PARAMETER TO FIT THIS?
MANY THAKS
CARLOS
Old 07-16-2007, 01:36 PM
ger21's Avatar
P is the tool diameter, so if you use P1 you'll get a 1/2" offset. Also, you need to add a lead in move for comp to be applied. If you can upload a .dxf and your code I'll give you a hand with it.
Old 07-25-2007, 01:31 PM
This Is A Copy Of The Drawing And The Program .
Many Thanks
Carles
File Type: txt MOSTRA_1.txt‎ (500 Bytes, 231 views)
Old 07-25-2007, 06:06 PM
ger21's Avatar
Try this. It's in absolute mode, and yours was incremental. The P specifies half the plasma kerf.
Old 07-25-2007, 06:08 PM
ger21's Avatar
Try this. The P specifies half the plasma kerf. I just guessed and used .5, assuming your using mm. Also, this is in absolute mode, yours was incremental.
File Type: txt mostra_2.txt‎ (700 Bytes, 251 views)
G-Rex & mach3 eloid Machines running Mach Software 7 03-15-2007 12:50 AM
constant velocity and power settings in mach3 plasma cutting Knut CNC Plasma and Waterjet Machines 4 09-27-2006 11:19 PM
Mach3 and USB mikep608 Mach Mill 3 08-09-2006 01:56 AM
ArtCAM & Mach3 for Plasma and Oxy sunmix Mach Software (ArtSoft software) 0 05-31-2006 02:01 PM
Mach3 Plasma anthony Mach Plasma / Laser 1 05-18-2005 07:21 PM
