Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 03-30-2006, 02:32 PM
barnon is on a distinguished road
Torch Height Control for PowerMax 1000
I have researched this site on the subject and look at Bob Cambells THC. I have also talked with a tech at Hypertherm and found out that j15 and j16 on a circuit board on the PowerMax 1000 is a tap for Voltage Height Control. Has anyone tried to monitor voltage in this manor for THC? Data Acquisition Card maybe. Seperate program or could Mach 2 monitor this value?
Old 08-10-2006, 10:08 PM
aghobby's Avatar
aghobby is on a distinguished road
We always monitor the voltage this way, but you need a voltage divider and a bord to communicate to Mach2
Alex
www.ebfcnc.com
Old 08-12-2006, 12:30 AM
Torchhead is on a distinguished road
J15 and J16 are the raw tip voltage (100 - 200VDC). Same voltage you can find on any plasma between the electrode lead and workclamp ground. Hypertherm is nice enough to provide defined connections for Tip volts, Torch Switch and Arc Good. MACH3 does not have support for analog input voltage.
