Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Plasma / Laser
Old 11-29-2005, 03:33 PM
Gold Member
mlaws1172 is on a distinguished road
Mach3 setup
I watched the video and it shows some menu's in diagnostics that appear just below the main menu for setting up e-stop auto reset,etc. This menu doesn'tshow up on mine. Why?
Also how do you set up the generic I/Os so Mach3 knows what is what? Like to turn the plasma on, initial hieght and arc prove?
I know I must be over looking something. Help please.
thanks
mike
Old 11-29-2005, 08:26 PM
ger21's Avatar
The video tells you it's in the Config menu, Ports and Pins. Can't help with the plasma stufff.
Old 11-29-2005, 10:37 PM
Gold Member
When you watch the video and he changes the e-stop to auto reset, the menu that he clicks on doesn't appear on my screen. Is that menu appear somewhere else?Have I turned it off some how?
Mike
Old 11-29-2005, 11:16 PM
ger21's Avatar
You don't have the menu at the top of the screen? What resolution are you running at?
Old 11-30-2005, 12:24 AM
Gold Member
I just downloaded the lasted ver. and it answered a lot of questions. The "SETTINGS ALT6" Doesn't appear in plasma. Limit override is activated by a pin input. But i can't figure out how to map a point to the torch on led and the torch ok led. Thanks for the fast response.
mike
Old 11-30-2005, 09:14 AM
ger21's Avatar
If you need a quicker response, send Art an email, or ask on the Yahoo group .
Old 11-30-2005, 11:14 AM
Gold Member
thanks. I think I have it figured out.
MIke
